jLink Java application startup failed - Creo 7 + JDK 11
  • November 13, 2024
  • 2245 views
We have 3 jLink (java) applications/plugins correctly running on PTC Creo 7 + Java 8. Now we're testing Creo 7 + Java 11 (because of future upgrade to Creo 9/10 with Java 11). We've compiled plugins files with a same JDK11 but one of the plugins fails running with message 'Startup of application "app name" failed.' Plugins configuration is same, they're using same otk/pfc dependency, same java version for compilation and same Creo 7 instance.
I've found this article but most of points are not suitable as other two plugins are running properly. Is there a more detailed log file of creo application startup to see any detailed information what goes wrong when starting plugin? Any other idea how to debug/investigate it?
Thank you very much.
Best answer by JurajKosmel
Sorry for a late answer - I forgot on it 🙂 Finally I was able to run the stuff by locating all libraries in one folder (with OpenJFX libs too) and adding plugins dependencies directly via Creo management tool configuration instead of manual records in configuration file. Now it is working and all plugins are running.
I hope you tried starting only 1 problematic application.
If you are active customer then you can contact PTC Support.
Yes, I tried several ways, even starting it separately, but no success yet. Juraj
I've tried several options/java versions and whatever and finally I'm able to start plugin to a Running state without fail (with most of initialization code commented out as it fails with it anyway) after editing creo config.pro file and moving lines
add_java_class_path path/to/openjfx
jlink_java_command java --module-path path/to/openjfx --add-modules javafx.controls,javafx.fxml,javafx.swing
before
add_java_class_path path/to/my/plugin/myPlugin.jar
Now I continue with the application code to find out what is failing there.
