I have a user defined parameter < UNITS > to capture Mass and Unit. That information properly displays in my drawing MP repeat region table. We now want this same information available in the model in support of MBD (model only). Specifically, we would like to show a note that appears flat-to-screen in a combination state. I tried applying < &asm.mbr.ptc_unit_units > in the note as well as dozens of other sequences - non work. Has anyone tried this method for notes with success?
First of all, are you talking about a single part or an assembly? If an assembly, are you intending to show the UNITS parameter for each of the components in the assembly?
Assuming that you're just intending to show the parameter either for a part or for the top-level assembly (and not for each component), you can just create a note including the text < &UNITS >.
We don't support repeat region tables as 3D annotations and thus the report parameters < &asm.mbr.xxx > are not supported yet either. That means if you wanted to show a table listing all of the assembly components in 3D you would not be able to do that today.
We are planning to offer a solution for assembly BOM tables in the MBD environment in a future release.
