Problem with Clamping Screws on the fixed half in EMX 7.0 M030
Bari
Hello guys,
we are having problems adding the fixed half clamping screws. As you can see in the image below, the offset value gets this awesome number. The Moving half its ok.
florin
(To:Bari)
Hi Antonio,
This is indeed a pretty long number. Even longer than the screw itsself.
I'll check it myself and then let you know what's wrong. As it looks like, I suppose the steps you made were add a clamping plate and a cavity plate and then the screws, right?
Florin
Bari
(To:florin)
Good morning Florin,
Yes thats exactly like you describe, add a clamping plate and a cavity plate and then the screws using the Mold base definition window.
Thanks.
