Autoupdate to appdata\local
  • December 18, 2013
  • 0 replies
  • 799 views
We are working with Direct Model and Drawing Manager 18.1. As soon as we connect to the server an update is initiated and the updated file gets installed in the folder "username\AppData\Local\PTC\Creo Elements\Direct Model and Drawing Manager 18.1". Additionally a shortcut gets created in the Current user Profile targeting the new executable.
My problem ist now: We are using roaming profiles, so the shortcut will roam but the files wont. When a user logs on to a different sytem, he gets an error because of the missing exe file.
Is it possible to disable autoupdate?
Is it possible to configure the update location?
chears
Chris
