Does anybody of you have real experiance with programming of multichannel NC mill/turn machines?
Customer has INDEX mill/turn NC machine with SINUMERIK 840D control system. This machine can have upto four turrets which could work independently. Movements of the individual turrets can be combined arbitrary. Each turret is programmed via separate NC program so called "channel". Inside of the control system, these channels can be synchronized via special programming elements called "waiting marks".
CREO 3.0 is able to prepare mfg models for such types of the machines. Unfortunately CL-data are generated into the one CL-file.
But I have no idea how to split postprocessor's output into upto four separate NC programmes-"channels".
A couplet years ago, I opened the case on it. But without any solution.
Does anybody of you have real positive experiance with this, in conjuction with CREO and G-POST?
