How can I get rid of probe (cursor)
  • August 3, 2014
  • 1540 views
Hi
How can I get rid of this yellow cursor (probe)?
Before I had a white cursor very convinient for draging (creating a box to capture stuff)
I cannot create a box to select elements! I have to click one by one every components!?!?!?!?!?!?
Even with F2 it dosent work!
Can I get rid of this thing?
Thank you very much
Are you by any chance using a 3D device such as a space pilot? If so, rezero the device. I have run into this issue more than once and the 3D device tends to be the culprit.
Regards
Tom
Opyone1-VisitorAuthor
Thanks for the answer....I am not using anything....
if you you have another idea I am there 🙂
One possibility is that you have "pre-selection" turned off. Find the Utility toolbar and make sure that the selection is set to All.
