8-Gravel
November 28, 2024
Model parameters not updated in Creo Draft file
  • November 28, 2024
  • 2 replies
  • 701 views
I am trying to create a new format with titleblock & other model details. When the parameters are added in the title block the same is not updated when model is called in the drawing sheet. Kindy help.
Naresh
Community Moderator
December 2, 2024
Hi @NareshJ,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team.
Are you working with Creo Elements/Direct Drafting and Drawing Manager?
If yes, your references texts should be in the format tb:NAME or tb:SCALE, etc.
