Add Values from variable KepWare to Chart
  • July 26, 2021
  • 2 replies
  • 2088 views
Hi
I'm want just to graph random data value from kepware to a chart in a mashup but I can not achieve this goal.
I can do it with a gauge or LED display but not with a Chart. Some idea? Have i to save the data before in a data storage or something?
Best answer by PaiChung
use services like QueryPropertyHistory or QueryNumberPropertyHistory or QueryNamedPropertyHistory
they will all be part of the Thing.
so in your mashup as you add data, browse to your Thing, then in services pick one of these and map the return to your chart.
To go fancier, map to the ThingTemplate and set it to dynamic and have an Entity picker.
22-Sapphire I
July 26, 2021
Yes you indeed have to save the data first so you have a table of information to display.
Create the tag in Kepware from simulation function within kepware. then Bind it to a Logged tag in a Thing. Be sure to assign a ValueStream to the Thing.
Now you can use services like QueryPropertyHistory or QueryNumberPropertyHistory or QueryNamedPropertyHistory to get the recorded values to display in a chart.
AitorP1-VisitorAuthor
Hi PaiChung,
Thanks for your answer,
I have a thing with 2 properties:
And I have a valueStream asigned to the thing too:
So now, is it necessary to create some event or service on the thing or on the ValueStream? or Have I to use the services directly on the mashup?
Thanks.
22-Sapphire I
July 26, 2021
I recommend a time series chart which will auto configure for the line graph you'll have to define the x and y
22-Sapphire I
July 26, 2021
Line chart can still work, do you have the 'widget switch' set to show all widgets?
