With reference to topic (Kepware/MT-Connect)
Do you know if the "Assets" is supported on the driver?
Greetings @AG_10894350,
There is no way to collect Renishaw MTCollector data using MTConnect; the Renishaw software looks to collect the MT Connect data.
I believe the next step would be to reach out to Renishaw directly to understand what interfaces (OPC UA) their software supports.
I hope you're doing well.
I am writing to inform you that, as of the latest available information, the Kepware MTConnect driver does not support the "Assets" category from the MTConnect standard.
I am trying to collect Renishaw MTCollector Data from the machine, do you know if there is a way I can configure the MTConnect Probe/Current to receive the Renishaw MTcollector information.
Regards!
Hello @AG_10894350,
It looks like you have some responses from our support expert. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
