BACnet I/P driver configuration details to browse tags from Johnson Controls & Schneider controllers
- September 18, 2023
- 1 reply
- 2746 views
Hi, my name is Ben Lau, the Project Engineer from a System Integrator in Hong Kong. I would like to communicate with the Johnson Controls NAE and Schneider SmartX controllers through BACnet I/P driver of your KEPSeverEX software. However, I have difficulties in configuration details:
- When attempting automatic tag generation for a node under Schneider SmartX Controller, the diagnostics window displayed completed status (only built-in tags generated by KEPServer BACnet I/P driver is available) but the following two warnings:
- "Error reading segmentation supported from remote device. Segmentation will not be supported."
- "Error reading object list from device. | Class = '1 (Object)', Code = '31 (Unknown Object)'."
- When attempting automatic tag generation for Johnson Controls NAE Controller, the diagnostics window displayed "Unable to generate a tag database for (Device Name). The device is not responding.".
- Please refer to the attached screenshots for current BACnet I/P settings for both onsite and the KEPServerEX software. Please advise the correct configuration settings in order to successfully communicate with the onsite controllers.
- For Driver (Channel) Protocol Setting under Properties, what is the local device instance for the BACnet I/P controller? Since BACnet Ethernet I/P settings in onsite application do not mention it. Thanks a lot!
Installed KEPServer Version: V6.14.263.0 (Demo Version)
Operating System Version: Microsoft Windows 10 Home 64-bit
