3-Newcomer
March 2, 2026
Booleans showing 0 not 1
  • March 2, 2026
  • 128 views
Hello, im setting up tags in Kepware where previously we have used RS linx, the booleans tags are all showing 0 when it should be a 1 and are not changing at all. The quality of the tag is good and its showing correctly (1) in RS linx but a 0 in kepware, anyone got any advice?
Kepware server 7
3-Newcomer
March 4, 2026
Hello, i checked the scan rate and its already set to 100ms, half the tags are correct and half are not even from the same rack and module is correct
Greeting!
I request you open a support ticket for further investigation on the concern.
Please log in to mykepware.com and submit a support ticket.
Mohit
