Has anyone configured a DMG Mori Machining center with a Mitsubishi controller? I am hoping to see what is available...
The DMG MORI document in the following link states their machines support OPC UA, MTConnect and MQTT.
I recommend utilizing OPC UA. You may need to consult DMG MORI support to see if the machines you have allows for these protocols.
*Chris
*Chris
