Device level scan mode?
AV_9656490
3-Newcomer
In Kepware ( KepServer Ex 6 server configuration ) what is the suggested Device level scan mode? What settings are appropriate to scan 1000s of tags under each device ?
  • Request all data at Scan Rate Vs  Respect Client Specified Scan Rate
For example , In our production system   I observed that "Respect Client Specified Scan Rate"  scan mode some opc tags are bad eventhough they are good on the source server side . After changing to " Request all data at Scan Rate",  most opc tags quality went from bad to good .
What are the pros and cons of the above settings on overall impact
MKhatri
(To:AV_9656490)
Greetings!
Please refer the given article for complete details.
https://www.ptc.com/en/support/article/CS278351
Mohit
MKhatri
(To:AV_9656490)
Greetings!
Mohit
