Greetings @AT_10876945 ,
To collect data from an auto-updating CSV file using KEPServerEX, you can follow these steps:
Create an Advanced Tag Group that corresponds to the data structure in your CSV file. Define Advanced Tags for each type of data you want to collect.
Export the tag group as a CSV file. This will serve as a template for your data. You can use Microsoft Excel or any other spreadsheet application that supports CSV files.
Modify the Template CSV File: Open the exported CSV file in your spreadsheet application, Add the initial data rows based on your requirements, and save the modified CSV file.
Auto-Update the CSV File: Configure your system or script to periodically add new rows to the CSV file. This can be done based on a cycle time or any other trigger (e.g., machine runs). The new rows should follow the same structure as defined in the template CSV file.
Import the Updated CSV File: In KEPServerEX, go to the Advanced Tag Group and select “File” > “Import CSV.” Choose the updated CSV file with the new rows. The imported data will be available as tags in your KEPServerEX project.
Monitor and Collect Data: Once the CSV file is imported, KEPServerEX will automatically update the tags with the new data rows. You can now read the data using OPC Client or any other compatible client.
Regarding using ODBC and a database:
- If your data volume grows significantly or if you need more advanced querying capabilities, consider migrating the data to a database using ODBC.
- However, if the CSV file meets your requirements, you can continue using it directly with KEPServerEX.
Note: CSV functions are only available when an Advanced Tag Group is selected.
Please take a look at the following article
Article - CS341300 - How to use csv file to import/export tags in PTC Kepware Products
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
