How to deploy kepware in production environment?
  • June 12, 2024
  • 2 replies
  • 1390 views
Our project is considering using KEPServer but I still don't know the process to bring KEPServer from development environment to real use. Please let me know what documents I should look for and where to find this answer. Thank you.
VladimirN24-Ruby IIIAnswer
Hi VladimirN
Thank you so much for your reply. But I can not find the document in the link you attached. Can you help me suggest another link to get the document?
Thank you so much
for further information, our project will using PLC of Mitsubishi and using Mitsubishi Enthernet driver.
Community Manager
June 20, 2024
Hello @HuyenDuong,
Please check if this link helps?
And if you found the correct link and it helped to answer your question, please document it by replying to this topic and mark it as the Accepted Solution.
But I am replying to raise awareness. Hopefully, another community member will be able to help.
Community Moderation Team.
