6-Contributor
February 23, 2023
How to get string from Mitsubishi Q series PLC?
  • February 23, 2023
  • 2 replies
  • 2324 views
We use Kepware to collect data from Mitsubishi Q-series PLCs and process it in ThingWorx.
I'm trying to set the device using the Mitsutubishi Ethernet driver and get the data from the PLC's data register as a string, but I can't select "String" from the data type in the Kepware property editor.
An integer can be obtained by selecting the "Word" data type.
Is there a way to get the string using Kepware?
Or do I have to create a service that takes an integer in Kepware , converts the integer to ASCII code and generate strings in ThingWorx?
Best answer by MRohilla
Greetings!!
It depends on the version that you are using, for KEPWARE versions 6.9 and 6.10 you may ask for the patch to install by submitting a support ticket, and the issue was fixed in version 6.11
You may visit the reference knowledge base article for it.
Mohit
22-Sapphire I
February 23, 2023
Probably want to post that in the Kepware forum.
MRohilla12-AmethystAnswer
Greetings!!
Mohit
