Hey guys !
I know this question has already been asked but no answer was given.
I am using the KEPServerEx V6 and I want to read values from #10000 and beyond (there is no letter at the beginning, just #) via the Fanuc FOCAS com. protocol. When I try to do so, I am getting the error :
"Address '#10095' is out of range for the specified device or memory type."
There is nothing for that range of addresses in the appended pdf.
Thank you !
Please take a look at the page in the manual in the following link which covers acceptable addressing with Fanuc Focus driver:
https://www.ptc.com/store/-/media/kepware-store/en/manuals/fanuc-focas-ethernet-manual.pdf#page=37
When choosing "Open" for the "model" selection" in the device properties; you can reach addresses up to 32767. I presume you have chosen any of the other models in the device properties which allows a max address of 9999 for custom addresses.
*Chris
*Chris
