How to remove the IoT Gateway from my project.
I was working with Kepware on a problem and during the discussion we enable a trial of IoT Gateway. I wont be using it in my application. But now it is filling my event log with "Time limited usage period on feature IoT Gateway has expired." Also, while on a trial of KepServer and this IoT Gateway, a notification shows up every 30 seconds to tell you it is a trial with limited time. It was so distracting I just uninstalled the software and work remotely with the actual licensed software. Now I just need to get rid of the IoT on that.
Scott
