Transferring a license from a development server to the production server, it looks like this can be done as long as you have access to the MyKepware account the license originally came from and it still has support?
Must also use the same MyKepware credentials when transferring that were used for the original activation?
What happens if the perpetual is out of support? Do you have to buy support to be able to move it to a new VM?
When you are done with development can you move the license info to the end-users MyKepware account?
Found this info on how to move and then activate the license.
Hi @Tanquen
Yes, you can use any MyKepware account to activate it, after activation the license ID will be associated with that MyKepware account.
Greetings @Tanquen
Let’s address your questions regarding transferring Kepware licenses
Transferring Licenses from Development to Production:
Perpetual Licenses and Support:
Moving License Info to End-Users:
So you can not move a license without support?
"eligible for VMware support" Like how just going back to a snapshot deactivates the license and you need support to reactivated it.
Default support after purchases is 60 days?
Sorry, I missed the part about moving license information from one MyKepware account to another.
Greetings @Tanquen
I would like to inform you that the license ID should be under support ensuring assistance if any issues arise the license ID should be under support.
No, Support contracts are mandated with the purchase of the product for a minimum of one year.
So you can move a license without support but not recommended,
"eligible for VMware support" Like how just going back to a snapshot deactivates the license and you need support to reactivated it?
Sorry, I missed the part about moving license information from one MyKepware account to another. Where is the guide on that?
Hi @Tanquen ,
I apologize for missing that part earlier. Let’s address moving license information from one MyKepware account to another.
License Deactivation:
License Activation in the New Account:
"You’ll likely need to provide the Activation ID associated with the license."
So as long as you have the Activation ID and it's not currently activated, you can use any MyKepware account to activate it?
Hi @Tanquen
