KepServer Siemens Suite with the new S7-1200 G2 CPU?
  • March 10, 2026
  • 110 views
Hi!
Has anyone used the KepServer Siemens Suite with Siemens new S7-1200 (G2) CPU's?
Best regards
Pär
It appears that some users have successfully connected the S7‑1200 G2 PLC using the Siemens S7 Plus Ethernet Driver. However, please note that this driver is not included within the Siemens Suite.
You may consider using the Siemens TCP/IP Ethernet Driver, which is included in the Siemens Suite, to establish communication with this PLC.
For configuration guidance, please refer to page 76 of the driver manual.
If you require assistance with a proof of concept (POC), you may contact our pre‑sales team at presales.support@kepware.com.
