KepServerEx OPC DA Client get bad data from OPC DA Server while Quick Client get good data.
  • November 24, 2025
  • 2 replies
  • 261 views
The KepServerEx is configured as OPC DA Client to connect the OPC DA Server on another machine. It get callback failure and bad data. While using OPC Quick Client connected the OPC DA Server to get data directly. It get good data. Two servers are on the same domain but running with different Log On account.
Best answer by rajskumar
Please take a look at the following article as it may help resolve your issue:
CS436561 - Quick Client connects to the remote DA Server and shows good quality tags, but OPC DA Client driver is unable to connect to the remote DA Server in PTC Kepware Products
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials. Thanks
rajskumar16-PearlAnswer
Community Manager
December 1, 2025
Hello @PA_8832783,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
