3-Newcomer
January 30, 2026
Kepserver tag quality turns bad(Configuration error)
  • January 30, 2026
  • 175 views
Hi!
I have upgraded from kepserverEX v5 to v6 on a new server, and tranfered the license:)
My problem is that after a while all tags stops working and i see tag quality turns bad(Configuration error). It shouldnt be licens cause i see status on license utility=good.
I then need to restart kepserver and it works again, so it kinda looks like license issue but idk how  😐
Anybody knows how to deal with this issue?
Best answer by ntripathi
Greetings @LB_14394759
I hope you're doing well.
I would suggest that you please verify whether the support end date displayed in the License Utility is correct.
ntripathi15-MoonstoneAnswer
