Kepware Configuration API Services: certificate update
LP_10773312
Is there a way to update certificates through an API service for Kepware?
Or another way to automate this?
MKhatri
(To:LP_10773312)
Hope this email finds you well.
I am writing to inform you that it is not possible to update the Kepware certificate via the Configuration API.
The update must be done manually in the Kepware Administration utility, as outlined in the following article: https://www.ptc.com/en/support/article/CS337909.
Additionally, please find attached another article detailing the process for updating the certificate: https://www.ptc.com/en/support/article/CS387585.
If you have any further questions or require assistance, please do not hesitate to reach out.
Mohit
MKhatri
(To:LP_10773312)
Mohit
