Kepware opc da connection
I'm trying to make a remote connection between a OPC client to a OPC server (Kepware).
On the server side, after adding the device and channel (OPC-DA), I was able to find and import the tags from the client, but they all show that the quality is "Bad" and also have no value. On the other hand, when I add the tags directly in Kepware's tag management (OPC quick client), I can observe the tags and see that they're value is changing.
I ve tried dcom configuration but i am already in same pc.
In short, I have a connection with the client, I'm just unable to receive any value when I add the tags through the device connection I’ve set up in Kepware.
