When communicating with Mitsubishi PLC via Mitsubishi Ethernet from kepServer, I wonder if it is difficult to link if they are on different networks.
I have already confirmed that linking is possible on the same network.
Translated the topic from Korean to English using google translate.
Body - kepServer에서 Mitsubishi Ethernet을 통해 Mitsubishi PLC와 통신할 때 다른 네트워크에 있으면 연동이 어려운지 궁금합니다.
같은 네트워크에서 연동이 가능하다는 것은 이미 확인했습니다.
-By Community Moderation Team.
Multi-level networking will work as outlined in the page in manual provided in the following link:
I also recommend opening a support ticket with the Kepware team to assist with analyzing your specific architecture.
*Chris
Thank you for your response.
I checked the contents of the link you sent me.
But what I wanted to know was the approach in a completely different network.
In the example on page 16, you can see that PLC 3 serves as a relay device connecting two networks. Is this not what you are describing?
Are you wanting to attempt the connection without the relay device? This cannot be done through KEPServerEX. I think you would benefit from opening a case with the Kepware team to get a complete look at your potential set up. Here is a link to the login page where a ticket can be submitted:
*Chris
The content on this page suggests that 192.168.111.1 and 192.168.111.3 belong to the same CIDR block.
My question is whether it's possible to access a Mitsubishi PLC on an internal network using KepserverEX on an external network.
Multihoming you NIC may be best option to complete the desired connection. Here is a link our document on how to configure the multihoming:
I still recommend opening a support ticket so the Kepware can analyze your exact set up needs.
*Chris
