6-Contributor
April 10, 2024
MTConnect Memory issues
  • April 10, 2024
  • 893 views
It appears that we are encountering difficulties when incorporating MTConnect devices into our system. These devices appear to be consuming significantly more memory compared to other devices. Specifically, after adding 23 MTConnect devices, Kepware crashes upon reaching the memory usage limit. Has anyone else encountered this issue?
Best answer by cmorehead
@MM_10545292
There are no known memory issues related to the MT Connect driver in the Kepware release note. I recommend opening a support ticket with Kepware team to assist with troubleshooting your specific architecture. Here is a link to the login page where a support ticket can be opened:
Log In | My Kepware
*Chris
cmorehead13-AquamarineAnswer
@MM_10545292
Log In | My Kepware
*Chris
