Missing or invalid keyword error message - KEPserverEX log
  • August 20, 2024
  • 2 replies
  • 712 views
Hello community,
We're experiencing issue where errors attached bellow pops up and it seems like this problem causing outages in our MES visualization system.
Any ideas what can cause this error message or how to deal with it?
Thanks in advance for suggestions.
JT
Greetings @J.T. ,
To address this issue kindly follow the below steps.
  1. Verify the machine cycle time and adjust the configured Request Timeout accordingly
  2. Verify the device follows EUROMAP63 specifications
  3. If the vendor software controlling the press generates a log file, refer to that file for more details on the problem
Please refer to the below article
https://www.ptc.com/en/support/article/CS378317
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
Catalina
Community Moderator
August 23, 2024
Hi @jt_01_10997478,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Moderator
