No longer be able to receive data from KEPServerEx when changing property from read only to read/write
  • August 14, 2017
  • 5051 views
By default,when binding data with remote thing from KEPServerEx, the binded property is read only. And I can see data coming in. But when I changed this property to read/write mode, It no longer be able to receive data any more. Even I rebind it, there is no new data received.
Anyone can help?
Thanks & Best Regards
Tom
Best answer by AnnaAn
Hi Tom,
Indeed I had the same issue per my test locally.
I will open a Jira to R&D to confirm if this is an bug or configuration issue.
I will open a new case for this case to track the Jira progress.
I will contact you through the case thread.
So we could close this thread now.
Br,
Anna
Hi Tom,
Did you try to change Read-Only to Read/Write on ThingWorx Thing Property or from Kepware itself? Make sure that you have configured Read/Write properly in the Kepware side and try again.
Br,
Anna
weli13-AquamarineAuthor
Hi Anna,
Thanks for your help.I changed the status of property inside Thingworx composer. I just tried to change it in the Kepware side, but after selecting read/write, and hitting OK buttion,it changed back to read only.
AnnaAn14-AlexandriteAnswer
Hi Tom,
Br,
Anna
