Good morning,
I frequently encounter the following error when connecting via OPC-UA:
Date Time Level Source Event
19/06/2025 13:01:03 Warning OPC UA Client B&R | Read request failed on device. | Status description = 'The operation timed out.', Status code = 0X800A0000.
Thank you.
As a next step, We would recommend capturing unencrypted packets using the Wireshark tool to help observe the communication at the wire level.
Alternatively, you may consider submitting a support ticket with the Kepware Technical Support team, who would be happy to assist you in analyzing the packet data. Thanks
Please take a look at the following article as it may help resolve your issue:
https://www.ptc.com/en/support/article/CS419647
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials. Thanks
