Problem Industrial Connectivity with Fanuc 30i
  • August 30, 2019
  • 2289 views
I have a problem when I try to connect Fanuc 30i-A PMC with Industrial Connectivity. The failure is the next:
I selected the appropiate channel and device, I downloaded Fanuc focas library I and II and I installed on Windows System32 folder, but the problem continue. Anyone knows about these libraries or how to connect with Fanuc PLC/CNC?
Thank you in advance
BR,
Luis
Best answer by vangne
@ljam
Please check this article to get more information regarding the required libraries when using the Fanuc Focas Ethernet Driver in ThingWorx Industrial Connectivity.
You may also refer this guide for more information thingworx-industrial-connectivity-guide
Vibhuti
ljam1-VisitorAuthor
Sorry I forgot upload the image of this error.
vangne16-PearlAnswer
@ljam
Vibhuti
