Siemens TCP/IP can't read high address
YN_8836362
3-Newcomer
I have issue reading reading higher address from the same DB for Siemens TCP/IP driver (S7-400).
I'm able to read e.g. DB15.INT3334 but not DB15.INT3396.
The error code is "Unable to read data from device. | Data block = 'DB15', block start = 3396, block size = 2, Reason = 'Device returned data access error'. Error code = 0X5".
I have tried the following but still doesn’t resolve it.
  1. PDU size of 240, 480, 960
  2. Increase request timeout from 5000ms to 10000ms
  3. Redownloaded DB15
I have another model 410-5H which can read such high address unlike 417-4.
Is there any settings in CPU properties which limit the read address memory?
Does anyone faces such issue?
ntripathi
(To:YN_8836362)
Greetings @YN_8836362
I hope you're ding well.
Please take a look at the following article as it may help resolve your issue:
Article - CS281555 - Error Unable to read bytes[...] Device returned data access error [Code=0x05] using Siemens drivers in PTC Kepware Products
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
Thanks, but this solution does not apply to my case.
