Thingworx - Kepware connection cannot be achieved without renaming the industrial thing.
Hello
I encountered this problem more then once.
I setup Kepware to connect Thingworx via named IndustrialThing name for example "conn". And i save this created Industrial Connectivity Thing to fetch remote tags and bind them to our properties. The method i use is to create a Remote Thing manually and Add IndustrialGateway ThingShape to add IndustrialThing property to the thing. After that i manually add "conn" to property. After saving the Thing i can do Manage Binding to bind remote tags to my property.
After using this method for 4-5 months on a company, Kepware start to give error to "Connection to ThingWorx failed". After that, I try everything to fixed that but nothing seems to solve these issues. The only workaround i did find is renaming the "conn" IndustrialThing name from Kepware. For example, I renamed "conn" to "conn1", Kepware is connected to Thingworx. But I have to save this "conn1" IndustrialThing and change IndustrialThing properties to of RemoteThings to "conn1". It is very time-consuming and the customers are not happy with this unstable connection issue.
After a few months later the same problem reoccurred. I have to change "conn1" to "conn2" to make Kepware able to connect and send data to ThingWorx.
Is anyone encountered this problem before ? Are you able to solved this ?
We are using the ThingWorx version 8.5. Planning to upgrade TWX 9
Thank you.
Murat
