When will the Tia portal Exporter support Tia portal V20 Projects ?
Greetings Frederik
Greetings @FV_8497961,
I’m writing to inform you that a final decision has not yet been made regarding this matter. However, please note that it is not expected to be added until the end of the year, in December.
Hello, is there a solution now?
Per the release notes, support for this TIA Portal version has been updated coinciding with the V7 release.
