Writing data from KEPServerEX to RSLinx/ Allen Bradley PLC
Hi all,
I am currently working on having a manufacturing execution system (MES) my company uses to writeback values to one of the PLCs it talks to. Our MES is on a virtual machine, let's call it APP014 & Kepware is also installed on this server. RSLinx/our OPC topic configuration is held on a separate server, called "GE".
Our current communications configuration is using Kepware as a middleman to talk to RSLinx (in other words, Local Kepware to Remote RSLinx) so that we can retrieve tag values from our PLCs. This is done as a read only process; we are using these tag values to provide real-time data to our MES. However, OPC writeback has never been implemented.
Contacting the OEM of the MES, I am able to writeback tag values to the Kepware OPC server, but I would need a separate functionality that writes the values from the Kepware server back to RSLinx, in order to edit tags in the reverse.
Does anyone know a way to perform this?
Thanks!
