logging vlaues of a property
  • February 20, 2020
  • 2 replies
  • 2902 views
I have a property whose values are coming from kepserver(datas are simulated with sine function). I want to log those data for every one second. How to do this?
I have checked in the logged check box in properties, and in advanced settings, i have given Always as a data change type. Bu,t when i execute the "query named property history" service for last one minute it is taking 5 minutes delay to give the result and it is showing the values logged in milliseconds instead of seconds.
Best answer by PaiChung
In your situation the best way to get a recording very second is to set that on the Kepware side.
The channel should feature a 'scan rate' which you can set to I think 1000 (milliseconds)
If you are transmitting every millisecond right now, then you are probably overloading the platform which might be causing the slow response.
But how often the data are coming from Kepserver?
Raluca Edu
PaiChung22-Sapphire IAnswer
22-Sapphire I
February 20, 2020
Sruthi15-MoonstoneAuthor
yes, the  scan rate of the tag was in 100. I changed it to 1000. Thanks for the reply
