3-Newcomer
April 24, 2023
one or more features are time limited
  • April 24, 2023
  • 5 replies
  • 11398 views
Hi, how can i fix this on Kepserver
i tried to restart, stop reset service and remove everything and make new device and connection again
but still have same problem
i use free version and i have used before, some months ago and i had not any problem
how can i fix it
thanks in advance
Best answer by pshashipreetham
Hi @DSX ,
Since you are using a free version, this is a License Issue; once you restart the KepServerEx, within 2 hours you get his error, the only way to avoid is to buy the license or restart the KepServerEX every 2 hours
Articles:
DSX3-NewcomerAuthor
3-Newcomer
April 25, 2023
thanks, but i have tried this before and doesn't work at all
We have the same issue. Have you resolved the problem? If yes, how?
Greetings,
We are waiting for your response.
Please share you direct dial no. so that we can connect with you and discuss this issue further.
Regrads,
Mohit
18-Opal
May 29, 2023
Hi @DSX ,
Greetings!
Does this Post answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Mohit
Greetings!!
Since your question has been answered I have marked the appropriate response as the solution to your post. If you disagree with my choice please let me know.
Mohit
