8-Gravel
November 5, 2019
Activating special function for milling
  • November 5, 2019
  • 3715 views
How would you capture and differentiate the 3+2 axis machining and 5 axis machining. For example when I have 3+2 axis insert a command and when in 5 axis insert other command.
What is it you need specifically? Possibly have your post capture if there is MULTAX in the code for 5-axis path.
john8-GravelAuthor
8-Gravel
March 2, 2020
hi, sorry for my late response. Yes, for example, a newer controller has special commands that allow having the part on a different location on the table without the need to repost. For Haas these functions are G254 and G234 , one is 3+2 axis machining and the other one is for 5 axis continuous machining. How would post one function or the other?
Regards!
john8-GravelAuthor
8-Gravel
May 6, 2020
hi, yes I will have a look in FIL/GPost  manual, they have all kind of exemples there. Thank you!
