3-Newcomer
May 24, 2025
Contour Ck Issues in Parting Surface
  • May 24, 2025
  • 571 views
Hello, dear community members!
I want to design a mold cavity, but I am stuck on "Volume Split." I can't run this command, and after doing some research, I noticed that the problem is related to the "Parting Surface." I received the following error:
The parting surface has 3 contour(s), make sure that each is necessary.
Could you please help me solve it?
Please check the attachments as well.
Catalina
Community Moderator
May 30, 2025
Hi @Ramin_Mahmoudi
Thank you for your question.
Best regards,
Catalina | PTC Community Moderator
