Create a custom drilling cycle, regarding to the Gpost formats, with some samples
I am using Creo Parametric Release 4.0 and DatecodeM130
we want to create a custom drill cycle and prepare the code inside the Gpost , the following movements are wanted :
1)Approximate feed rate max (G0), coolant :Off, RPM = 500,
2) Drill the first deep 1.5 x Ø of the drill with 10% ( 30) of the worging feed rate =F300
3) Drill the hole deep with working feef rate (F300) and RPM =3.000 and coolant : ON
4) return the to the first deep with F=500 RPM=500
TKX
TKX
