Creo 5.0 HSM Rough
  • November 30, 2018
  • 5410 views
Having issues with HSM Rough, Parameters are set up for Rough Only, Constant Load, Step Over .03 , Max Step Depth .625
Issue with this is it still wants to do a full retract when the tool path starts to work in corners. Instead of doing a small tool lift.
Any suggestions or solution's would be appreciated.
Best answer by BillChapman
Also set
MIN_RETRACT_DISTANCE 8
8 inch  or some other large number
Also set
shaun11-VisitorAuthor
That seemed to solve my issue, Thank you!
I am using 5020 and cannot find this option in my parameters.
Where is it ?
