How to control line space in a ptc font?
We want to use the leroy font for some signs we're manufacturing. But since the heigt of the leroy font is defined wrong (when you set the text height to 5mm, the lowercase letter turms out 5mm high) and it also refers to a latin font which look completely different, I have made a copy of the leroy font and made som changes.
These are the settings in the original file:
codeset 0
height 63width 36
base_offset 11
spec_height 26
xextent 36
fixed_width 1
ascender 11
polygons 0
ics 1
gap 8
These are the settings after my changes:
codeset 0
height 59
width 36
base_offset 11
spec_height 37
xextent 36
fixed_width 1
ascender 11
polygons 0
ics 1
gap 8
This gives the right height of the font. But I have the problem that when I write a note with more than one row, the base_offset of the row above collides with the ascender of the row below. I have tried to change the height and the ascender to 63 and 15. But the text comes out the same.
Does anyone know how to control the line space?
