I am looking for a text font for engraving like Leroy with wider character spacing.
  • February 18, 2016
  • 2 replies
  • 6043 views
The spacing on most of the single line character fonts in Creo do not allow for the width of the cutter used in engraving. Is there a way to space the characters? Is there a source for engraving fonts which consider cutter width?
can you use the aspect ratio to stretch the letters out? not sure if that will fix what you are after but it might.
The aspect ratio stretches both the spacing and the characters, to get the right spacing the characters are out of proportion.
Yes it does stretch them. Just a thought for a quick fix if you only needed a little more spacing. not sure about different fonts. I believe you can import fonts from other sources. I have never done it so I am not much help there. Also the letter spacing is pretty much a standard unless you can copy each of the letters as a sketch then space them your self.
If this engraving operation is something you need to do on regular basis then you may want to consider to create your own dedicated font for engraving.
In the attached file look at the "How to Edit Fonts or Create New Fonts"(page 123) and the following sections for details regarding font creation.
I think you will need to change the value of the "gap" parameter on the font header:
# Leroy Font Set (C-02-27)
# Steven Young
# July 20, 1992
#  20-Jul-92 $$1 Submitted
#  25-Jun-01 J-03-02 rmi   $$2  Added caret and underscore
codeset 0
high 63
width 36
ascender 11
spec_hight 26
base_offset 11
fixed_width 1
ics 1
gap 8
The font parameters are explained in "Font definition" section starting at page 112.
attention! ... Text font is made up from linear segments, only. Also PTC does not offer graphic editor enabling font creation.
I think that the simpliest solution is to create individual letters in Sketcher mode and save them as separate .sec file or as Sketch features.
MH
you replied to discussion more then 1 year old. It does not make any sense ...
... and I do not understand, what you mean with your reply.
