Inch programs to metric output?
I would like to switch my milling center to metric but all of the programs we have created and use over the last 10 years are in inch. Is there a easy change that i can use to output older inch based programs to metric? I have tried outputing a CL file and changing the units to mm but the feeds do not change only the length units change.
