Mill Window stock clearance
  • April 5, 2013
  • 2 replies
  • 3502 views
I need some help with a 'Mill Window' roughing sequence. The tool is coming down tangent to the 'Stock' which is not safe. I would like the tool to plunge in the space around the material. Does anyone know how to set a boundary or an offset for that?
Thanks!
Best answer by NickMihelich
yes mill volumes are your only viable option for this and add approach surfaces to control the entry of your tool
could you throw up some screenshots?
Sorry Nick. I should have done that to start with.
No worries try this parameter.
Thanks for the help Gentlemen! I was able to get the path that I wanted with your help.
