No retract between holes when drilling
Occasionally I encounter this problem with drilling sets of holes. When creating a drill sequence of two or more holes, the path produced will drill the first hole, then without a Z move of any sort, it goes to the second hole's position. The fix for it is to create multiple sequences rather than selecting multiple holes for the same sequence. Most of the time everything goes as it should, but I can't trust that it will.
T1
M6
T1
S1030M3
G1G43X-.75Y-2.156Z1.F300.H1
G81X-.75Y-2.156Z-6.4231R.01F9.1
Y-1.356
G80
G1Z1.F300
M9
M5
G0G40Z3.0
G5P0
G28G91Z0
G49
G30
I prefer to see:
T1
M6
T1
S1030M3
G80
G0Z1.
Y-1.356
G80
G1Z1.F300
M9
M5
G0G40Z3.0
G5P0
G28G91Z0
G49
G30
I've ran this through a few different post processors and get the same result. My guess is that it happens 1 in 20 times for me. Usually a good operator catches it if I did not see it in the path before it got to them. Curious if anyone else gets this issue?
Creo 2.0
Matt
