thanks for your reply..yes i am using iso post processor..most of cycle .which i generate thru this pp is working fine ..except drilling taping reaming etc cycle...by default the current processor generate drilling cycle with this format.
but i dont want to use this canned cycle due to some restriction(2nd setup clearance not available ) in this format ..
..i am sending you conversational post processor which i want to use only for drilling taping and reaming purpose please if you can update it or guide me how i can update on below mention format
0 BEGIN PGM 201RM10 MM 1 BLK FORM 0.1 Z X-400 Y-400 Z-75 2 BLK FORM 0.2 X+400 Y+400 Z+3 3 TOOL CALL 1 Z S80 4 CYCL DEF 201 REAMING ~ Q200=3 ;SET-UP CLEARANCE ~ Q201=-30 ;DEPTH ~ Q206=30 ;FEED RATE FOR PLNGNG ~ Q211=0 ;DWELL TIME AT DEPTH ~ Q208=80 ;RETRACTION FEED RATE ~ Q203=+0 ;SURFACE COORDINATE ~ Q204=50 ;2ND SET-UP CLEARANCE 5 L Z+50 R0 F3500 M3 6 L X-262.99 Y-146.925 M99 7 L X-303.002 M99 8 L X-305.002 Y+130.225 M99 9 L X-228.002 Y+166.1 M99 9 L X-106.487 Y+157.861 M99 9 L X-29.002 Y+164.233 M99 9 L X+28.999 M99 9 L X+106.484 Y+157.861 M99 9 L X+227.999 Y+166.1 M99 9 L X+304.999 Y+130.225 M99 9 L X+302.999 Y-146.925 M99 9 L X+262.99 M99 10 L Z+50 R0 F3000 M2 11 END PGM 201RM10 MM..
right now conversational post processor output in below mention format
1 BEGIN PGM DRILLING_1-CONVERSATIONAL MM 2 TOOL DEF 17 L0 R0 3 TOOL CALL 17 Z S3 4 M3 5 M8 6 L Z-20 F M90 7 L X+31 Y-12 F M90 8 CYCL DEF 1.0 PECKING 9 CYCL DEF 1.1 SETUP 2.00 10 CYCL DEF 1.2 DEPTH -4.00 11 CYCL DEF 1.3 PECKG 1.00 12 CYCL DEF 1.4 DWELL 0 13 CYCLE DEF 1.5 F100 14 L Z+10 R0 F M99 15 L Y+77 R0 F M99 16 L Z-20 F M90 17 M9 18 M5 19 M30 20 END PGM MM
hope you will understand..also attach creo mfg test model files and both iso and conversational pp
