Radius issue exporting geometry for CNC
JustinSauber
My company has just recently started using solid models to create machining programs in GibbsCAM. We are experiencing issues with radii where there are more points in the radius than the standard 3 points (start, midpoint, end). Has anyone else had this issue and if so have you found a solution.
1 REPLY 1
Or the export-import process converted the circles into curves, or the originating CAD-system represents circles as a special case of curves.
Met vriendelijke groeten, Best Regards,
Hugo.
