Surface finish with volume rough
I have a problem of surface finish with a volume rough.
The previous operation leaves 0.2mm of stock (walls and bottom) for the finish with my volume rough. I choose a spiral toolpath and i have sharp edges between each trajectory segments. In the real world this create micro stops of the servos of my milling machine and a very bad surface finish.
So i decide to apply a radius with the option "Smooth_corner_radius = Max radius" and "Smooth_radius = 1" (End mill of 6mm diameter).
The problem :
The calculated trajectory miss some areas of my surface...
Same problems with "constant_radius" and angle_radius" for "Smooth_corner_radius", smaller radius value and thinner "step_over".
Some ideas ?
Thanks in advance
