Tapered scallops
HI eveveryone
ive got to machine some tapered grooves/scallops around a tapered handle. The grooves have an axis ,was hoping to just come down vertically with my cutter following the axis which is at 5 degrees. Do I use trajectory milling ? I'm using creo 2
thanks for any help
