imported solid tooling for manufacturing
  • February 24, 2026
  • 82 views
how do you modify imported Kennametal boring bars to work in the simulation section in creo manufacturing. i dont know where to start on how to get tool to work
Hi
You must have a coordinate system named "Tip" at the exact point where you want the tool to follow the path.
Regards
Pushkar
Just a bit more info on that: The coordinate system must be oriented with Z+ along the spindle center, away from the tip of the tool.
Myself, I don't really use the solid tools. I suppose they would be helpful to avoid collisions, show actual depth of cut limitations, etc. but if I recall they made material removal simulation difficult? I can't remember.
Community Manager
March 3, 2026
Hello @NE_10013616
It looks like you have some responses from some community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
